Suds
#1 Posted : Friday, April 22, 2011 10:31:51 AM(UTC)
Suds
Ok, I'm stumped.
How do I go back to the 3D view from a model to sheet view?
mlochala
#2 Posted : Friday, April 22, 2011 10:47:20 AM(UTC)
mlochala
Model to sheet is just stored on a separate layer from your 3D models. When you use this function, a new layer is created and at the same time de-activates the layers where you have been working.
Go to your upper menu and choose Window>Concept Explorer. Once Concept Explorer opens, select the Layers tab. There, you will see that your active layer will be Sheet View 1 (or something similar). Turn that layer off and then turn back on the layer where your 3D models reside.
Suds
#3 Posted : Friday, April 22, 2011 11:09:38 AM(UTC)
Suds
Thank ya much!
Didn't think to look at the layers :p
