Craig
#1 Posted : Monday, September 6, 2010 4:43:01 AM(UTC)
Craig
I have used a 3 point arc for the rails in the surface I have swept, problem is that the arc is not a true arc so the surface will never be smooth. I changed resolution from very fine to super and it did produce a better result.
Am I missing something here?
TwoRailSweep.sfx (528kb) downloaded 0 time(s).
#2 Posted : Monday, September 6, 2010 8:58:23 AM(UTC)
Hi Craig
See if these help
1st when you select the curves and go to edit change resolution check the even distribution box in addition to changing to super fine
2nd Select the object and edit change resolution and turn on precise facets for surface
Craig
#3 Posted : Monday, September 6, 2010 11:58:30 AM(UTC)
Craig
Hi Craig
See if these help
Thanks a lot Jason, I was changing resolution with the right click menu so you don't get those options.
