Craig
#1 Posted : Monday, December 6, 2010 9:33:10 AM(UTC)
Craig
Simple test, create a 20 mm circle, select it and set it to the highest resolution and zoom in on the edge and you will find it is not round. Then fill it with a surface and see the problems on the edge, this is causing me many problems, it also applies to arcs?
