#1 Posted : Tuesday, November 17, 2026 7:46:38 PM(UTC)
Was thanked: 129 time(s) in 88 post(s)
This may interest regardless of using CAD or using art-materials foam or similar board.
But, I suspect that depending on the facilities built in the agentic or AI tools Tim and Team are making or the extensions they add to it, there probably will come the ability to do preliminary or basic air flow modeling.
Imagine using high-speed camera gear to record injection and flow of color-dyed air (and, depending on how many cameras and dyes an examiner may want to study, more tracks for more colors, for the AI), having the AI write flow control scripts, being given access to the dye and the air release valves, and ability to modify the assumptions-deiging formulas/functions/scripts, then record them in the BOMs, then export to a generic brand-agnostic worksheet, then allowing for external analysis, then reincorporating manual or other modifications, and re-running the camera and flow via SharkCAD.
Even though agentic tools can get really close, it still could be a client requires an analysis that incorporates traditional physical tests using dyes, water or air, and fan or pump speed control.
Ever since around 2003, I've wanted to make a miniature or model ship hull model testing tank (non-new, non-novel idea/approach to *me*, but I would use a lot of trial and error to dodge IP claims of others) with, say, worm or screw gear calibrated to move water through variable ducts to simulate the speeds of a sandpapered or stippled plastic hull that is stationary in the test rig (to avoid needing a canal or anything bigger than a bathtub, barring air pressure factors) given the suitable amount of grit or salt since gracity and pressure can be difficult to scale for small objects.
With a different set of fans, scaled airflow could be used to list or heel the model (by creating a properly shaped enclosure and adding even more fans and ducts). Dyes in the air could help map out the viability of a superstructure shape with regard to helicopter operations on or above the flight deck and to model ship engine exhaust stack gas flows that might interfere with air crews and topside personnel.
If all this can be done, the amount of generated dat would make for messy layers that would need to be pretty much automated or manually reorganized more than what the Concept Explorer is currently capable of.
"Making an at Home Windtunnel using PC Fans: Going to test Pinewood Derby..."
https://youtube.com/watch?v=TTd--O7dkIw&
Computer Tech & More
