Greets all,
I'm learning how to use CAD as part of tooling up to produce custom guitars using a cnc router. At this point, I have about 4 hours of experience over a 24 hour period with CAD, all of it using ViaCAD. (I did try AutoCAD in the early 90's, but that's another story...)
I don't need photorealistic rendering, etc.; just accurate models of the guitar bodies and necks that I can transfer to my CAM software. I've already sorted out how to extrude a 2D body profile, and as the attached image shows, a neck profile.
At this point, my objective is simply to ensure that ViaCAD can make the shapes I need. After I'm done with this proof of concept stuff, I can get to working on fullsize models for export to CAM, something I expect to take a bit of time.
I'm hung up, however, on creating the transition from the neck to the neck tenon, the most complex curve, it appears, on a flat-topped solid body guitar (transitioning the headstock to the neck may be a contender). It's the nonsolid area in the attached image. I'm sure that I'm missing something, or doing something incorrectly, but not sure just what.
Thanks in advance for sharing your expertise!
 guitar neck exercise.vc3
(36kb) downloaded 6 time(s).You cannot view/download attachments. Try to login or register.
