cutsrock
#1 Posted : Wednesday, August 3, 2011 12:21:52 PM(UTC)
cutsrock
In VC 2D3D V8 Verify/Properties Dialog opens and User Defined Materials is in the radio box. Can scroll to other materials and density of that material is used to calculate properties or enter a value for User Defined Materials and properties are calculated.
Is it possible to enter additional materials into the Mass Properties file? ie; like adding symbols.
Thanks Jim
phil
#2 Posted : Wednesday, August 3, 2011 1:10:25 PM(UTC)
phil
I did it on SFX. If you can keep a secret .... it's the Materials.ini file :) Mine is located in the C:\Program Files\Punch! Software\Shark FX v7 BETA\Environ subdirectory.
I added "3M Rubber Foam" and "Bond Paper" in the [Misc] section and several related sections down in this Materials.ini file.
(yeah... bond paper or stickers/labels are not weightless if we have plenty in the assembly/drawing ha ha:))
Have fun!
bye
cutsrock
#3 Posted : Wednesday, August 3, 2011 4:00:58 PM(UTC)
cutsrock
Thanks Phil. It didn't occur to me to use that avenue. I use a lot of 6061-T6 Aluminum and it's Density is 0.0975 lb/in3.
Thanks again.
Jim
