Solid Modeling
hidden line color question (#4153)
                When I use the model to sheet function, I like to make my hidden lines visible and dashed. But my hidden dashed lines come out yellow in color. I have looked everywhere and tried to find an area where I can change the color, but no luck. Anyone else run into this?
                Hi  The dash line is default yellow  The hidden line is default red I would recommend making a custom line style and when you first build the model to sheet in the drop down select the custom line style for hidden. goto inspector ->pen properties ->in style drop down select new -> fill in values you want. Regards Jason
                Thanks Jason, That is the fix I was looking for. :-)
Solid Modeling
