jors
#1 Posted : Friday, September 30, 2011 9:50:42 AM(UTC)
jors
I am looking for a tutorial that will show the steps to design from scratch in 2D, then to surfaces and then to solid. In other words, other than solids natives.
la mouche
#2 Posted : Sunday, October 2, 2011 3:11:44 AM(UTC)
la mouche
Salut,
an advice if you are a beginner: you must allways solid model, if you can in relation to your forms.
Work surfaces and solid stitching requires excellent modeling discipline.
Indeed, it does not support any opening, tear, inaccuracy.
Antoine
jors
#3 Posted : Sunday, October 2, 2011 9:30:01 AM(UTC)
jors
Sounds like Blender and FSDS. Blender had snaps but not FSDS. So I know. Zoom in to the maximum just to see properly.
la mouche
#4 Posted : Sunday, October 2, 2011 10:18:54 AM(UTC)
la mouche
ok, I'll do a video tonight, for demonstration ;)
Antoine
la mouche
#5 Posted : Sunday, October 2, 2011 10:35:05 AM(UTC)
la mouche
a video with surfaces to solids.
If you want, i can another.
http://screencast.com/t/tqwUpMnSx8l
Antoine
jors
#6 Posted : Monday, October 3, 2011 1:04:31 PM(UTC)
jors
Thanks. Appreciate it.
jors
#7 Posted : Tuesday, October 4, 2011 11:00:57 PM(UTC)
jors
Thank. I worked through the tutorial. This is what I was looking for. Sometimes you want something that is a bit complicated for solids.
blowlamp
#8 Posted : Wednesday, October 5, 2011 2:22:22 AM(UTC)
blowlamp
Johan.
As Antoine has hinted, it's usually best if you can model straight from some kind of solid.
Some advice that I have taken on board about 3D modelling, is that of carving away sections from a base shape in order to 'reveal' your creation, in a similar way to how you would engineer a piece of stock material, in say a milling machine.
In ViaCAD Pro you can use curves, solids and surfaces to split and trim bits off base solids and base surfaces to rapidly make complicated shapes, which can then be used as cutting tools to help achieve your design goals.
I think you do already know this, but I believe it's worth mentioning because it is a powerful way of working to make an intrinsically flawless object.
Martin.
Redss
#9 Posted : Thursday, November 10, 2011 3:02:08 PM(UTC)
Redss
Thank You la mouche
daleroe
#10 Posted : Friday, June 6, 2014 5:33:22 PM(UTC)
daleroe
Antoine
Nice, it is interesting to see a different workflow. To create the same basic shape I would have created arcs and not had the flexibility you built into it with the splines. Thank you for sharing!
-dale
HP Z800 Dual Xeon 5690 3.46Ghz 64GB
nVidia Quadro 6000 6GB
Win pro 7-64
SharkCAD Pro v10.0.0 B1354
Shark FX v9.0.4 B1162
