Solid Modeling
"Welding" with filler? (#3978)
I have seen that you can with the Boss feature add a cylinder so that there is a round in the base that appears to be welded. Can it be done with two other solids? I am referring to a cylinder (Round or multi-cornered). cones, or blocks. I have tried to use the feature stitch as well as fillet surface, but no success. Is there such an option somewhere. The manual is not clear enough here.
no - not directly, but you can simulate it easily using a pipe or sweep tool ... you may need to 'explode' a curve(s) off first to for the pipe or sweep to be driven along (There may be a good feature request for Tim in your question Jors !)
Jol, It is working as a sweep along a curve. I will post a pic tomorrow. I will also try to do it for a block. Hey man, this program is real fun for a beginner. I come across the most weird problems and for each one there is a solution!
Well done Jors - your enthusiasm will see you well ! Well I agree, it's a terrific program ... and now's really a great time to learn CAD. I'm jealous of you guys starting now 'cos I learned CAD 20 years ago when it was just a big steaming pile of old boxers. Woohoo look I made a cube ... woahhh ! There is the odd hick-up now and again, but the guys here on the forum do their best to document problems - and Mr Olson and co. do their best to keep on top of the issues that come up. Keep up the good work !
Here's another way to fudge it quickly. Copy the two members that share the fillet intersection in place and thicken them. Intersect the thickened copies, then apply a fillet to the edge of the intersection object.
(26kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Rank:: Senior Member
Thanks: 233 times Was thanked: 184 time(s) in 111 post(s)
Originally Posted by: zumer Here's another way to fudge it quickly.
Great Fudge Zumer, thank you !
So far, no success yet.
I manage to draw a patter along a path for round objects and this is what it looks like:
-The one on the right is a bit overdone_
I don't know what to do about a square block yet.
I have looked at the manual, page 323, Fixed width and Hold Line.
Also on page 331 Fixed width Chamfer
Also page 346 about stitch operations. There is a picture with a below heading of Feature Operations on Surfaces.
This appearance is what I am looking for, but I will try again.
Do you mean like this?
Martin.
(28kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
No, It seems to me I am unable to get it right. The fillet tool for surfaces works for a cylinder but for a block. Nothing seems to work. The surface fillet feature seems to be for loose surface only. Though there must be a way because if I look at the gallery of Punch's web site I see models that have rounded off corners inside. But how?
Blowlamp Yes that is what I want.
Oh, that's easy enough. Make your base plate and the shaped block/extrusions and join them with the Add Solid tool, then use the Blend tool on them - that's all I did. Blend does both concave and convex radii, automatically. For the polygon, just select each edge you want radiusing. Martin.
Thanks. Now I can come to rest. [But only until I get the next obstacle. Most of the problems, fortunately, you can get the answers in the manual}.
Salut, make me a drawing of what you want. I do not understand your request, please. Antoine
Salut, It is working now. I am using the blend tool with success. I did not know you had to join your two objects first.
Solid Modeling
