jors
#1 Posted : Saturday, September 24, 2011 9:50:01 AM(UTC)
jors
I have seen that you can with the Boss feature add a cylinder so that there is a round in the base that appears to be welded.
Can it be done with two other solids?
I am referring to a cylinder (Round or multi-cornered). cones, or blocks.
I have tried to use the feature stitch as well as fillet surface, but no success.
Is there such an option somewhere. The manual is not clear enough here.
#2 Posted : Saturday, September 24, 2011 10:35:29 AM(UTC)
no - not directly, but you can simulate it easily using a pipe or sweep tool
... you may need to 'explode' a curve(s) off first to for the pipe or sweep to be driven along
(There may be a good feature request for Tim in your question Jors !)
jors
#3 Posted : Saturday, September 24, 2011 1:26:01 PM(UTC)
jors
Jol,
It is working as a sweep along a curve.
I will post a pic tomorrow.
I will also try to do it for a block.
Hey man, this program is real fun for a beginner. I come across the most weird problems and for each one there is a solution!
#4 Posted : Saturday, September 24, 2011 1:53:30 PM(UTC)
Well done Jors - your enthusiasm will see you well !
Well I agree, it's a terrific program ... and now's really a great time to learn CAD.
I'm jealous of you guys starting now 'cos I learned CAD 20 years ago when it was just a big steaming pile of old boxers.
Woohoo look I made a cube ... woahhh !
There is the odd hick-up now and again, but the guys here on the forum do their best to document problems - and Mr Olson and co. do their best to keep on top of the issues that come up.
Keep up the good work !
zumer
#5 Posted : Saturday, September 24, 2011 10:19:09 PM(UTC)
zumer
Here's another way to fudge it quickly. Copy the two members that share the fillet intersection in place and thicken them. Intersect the thickened copies, then apply a fillet to the edge of the intersection object.
weld fillet.jpg (26kb) downloaded 5 time(s).
#6 Posted : Sunday, September 25, 2011 2:17:59 AM(UTC)
Was thanked: 171 time(s) in 103 post(s)
Great Fudge Zumer, thank you !
jors
#7 Posted : Sunday, September 25, 2011 3:27:42 AM(UTC)
jors
So far, no success yet.
I manage to draw a patter along a path for round objects and this is what it looks like:
UserPostedImage
-The one on the right is a bit overdone_
I don't know what to do about a square block yet.
I have looked at the manual, page 323, Fixed width and Hold Line.
Also on page 331 Fixed width Chamfer
Also page 346 about stitch operations. There is a picture with a below heading of Feature Operations on Surfaces.
This appearance is what I am looking for, but I will try again.
blowlamp
#8 Posted : Sunday, September 25, 2011 4:17:18 AM(UTC)
blowlamp
Do you mean like this?
Martin.
jors
#9 Posted : Sunday, September 25, 2011 4:17:36 AM(UTC)
jors
No, It seems to me I am unable to get it right. The fillet tool for surfaces works for a cylinder but for a block. Nothing seems to work.
The surface fillet feature seems to be for loose surface only.
Though there must be a way because if I look at the gallery of Punch's web site I see models that have rounded off corners inside.
But how?
jors
#10 Posted : Sunday, September 25, 2011 4:19:01 AM(UTC)
jors
Blowlamp
Yes that is what I want.
blowlamp
#11 Posted : Sunday, September 25, 2011 4:35:07 AM(UTC)
blowlamp
Oh, that's easy enough.
Make your base plate and the shaped block/extrusions and join them with the Add Solid tool, then use the Blend tool on them - that's all I did.
Blend does both concave and convex radii, automatically.
For the polygon, just select each edge you want radiusing.
Martin.
jors
#12 Posted : Sunday, September 25, 2011 5:11:47 AM(UTC)
jors
Thanks.
Now I can come to rest.
[But only until I get the next obstacle. Most of the problems, fortunately, you can get the answers in the manual}.
la mouche
#13 Posted : Sunday, September 25, 2011 7:41:29 AM(UTC)
la mouche
Salut,
make me a drawing of what you want.
I do not understand your request, please.
Antoine
jors
#14 Posted : Monday, September 26, 2011 9:24:37 AM(UTC)
jors
Salut,
It is working now. I am using the blend tool with success. I did not know you had to join your two objects first.
