2D Drafting
Printing proble in V9 (#5114)
Seems to be solved partly. Reason is not quite clear. Closing V9 and restarting give print results, but the dimensioning in the sheets was not in line with the specs for printing. After closing the file and reopening this problem did not occure. But not for long. Still I encounter that sheets can not be printed. Even in the Setup and Layout I can see the sheet, fit it and can centre it. However Print will not result in a printout. Sometimes only the Title/Drawingframe is shown, and not the content of the sheet. Printing from the dynamica-window (and selecting the object in a view) is however succesfull. So the printer seems to work quit well. Is it that I do something wrong in the Setup or Layout? Jay
Hello Jay, If you can post an example, I can look into further. Thanks Tim
I would like to. But the upload from my computer showed: "Upload failed". The file is only about 2,5 Mb, and in vc3, so it should work. I will try later again. Jay
Tim,
I hope that the attachement now was succesfull.
I still encounter problems with the printing in V9.
1.Printing the sheets works. However the viewports switching a view in Gouraud or Phong (both with ot without edges) will give problems in printing. The Gouraud or Phong option show while printing a screen-height gray on the place of the object in that view.
2. I saved the file in V7. And run V7 on my old computer. And in V7 I did not encounter problems in printing. There the viewports in Gouraud or Phong withe Edges will turn up as desired.
Jay
Door.vs01.inV9.vc3
(1,037kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
2D Drafting
