#1 Posted : Friday, September 21, 2007 9:56:54 AM(UTC)
Was thanked: 169 time(s) in 102 post(s)
Did I say before I hate the dimensions settings ?
Every time I change scale (from nano-science to house building), it takes me 20 minutes to get it back correct (text, arrows, line parameters, offsets...).
Today, I'm reaching the limit : by fiddling the stuff by usual trial ans errors method, I lost all the dimension text.
It turned "###" (see picture).
Any hope to see this improved ?
JL
Image 11.png (53kb) downloaded 5 time(s).
Tem
#2 Posted : Saturday, September 22, 2007 4:41:01 PM(UTC)
Tem
I remember there being a text file that one could modify so that your dimension settings could be configured as the default.
I think the there is a file in Environ Folder called SysDimen.ini.
I believe that this can be modified in Apple's TextEdit or the MS's NotePad.
Good Luck!
#3 Posted : Monday, September 24, 2007 6:00:26 AM(UTC)
#4 Posted : Monday, September 24, 2007 6:02:02 AM(UTC)
Also for CU 5 ..
.. do we have text size, font and style showing up in the attributes of the Edit Object Box ?
Tem
#5 Posted : Tuesday, September 25, 2007 12:28:41 AM(UTC)
Tem
But Pro/E is so fun that way! ; )
Gary
#6 Posted : Wednesday, September 26, 2007 9:22:44 AM(UTC)
Gary
good 2D drawing is a current weakness in Concepts. I hope to see this addressed in next version. I think Tim said there were looking at it. Weaknesses fall in 3 main areas for me.
1. settings don't stick
2. some settings are not customizable (default pen styles)
3. custom pen styles can not be assigned a short cut key
Simply put:
a. I want to be able to set the line style as I like them
b. I want to be able to select them quickly with a short cut key
c. I want to know I am going to get predictable results when changing scales, views and files.
Achieve that and Concepts will be a very special tool that I can work in from concept to production drawings.
Gary
