Thanks: 218 times Was thanked: 169 time(s) in 102 post(s)
Hi, I had this issue many times this week with this tool: On attached file, skin the 2 red profiles with the guides. ---> the resulting solid is damaged, looking transparent Check object + repair makes it correct.:) Why doesn'it repair on its own ? JL Why can't I attach a file any more ?
Upload file seems to be broken. Here's the route to make it : first profile - 4 connected conics second profile - a circle Guides - 4 lines between conics and at circle quadrants. Good luck... JL
Still cannot upload a file... Safari & FireFox
jlm wrote: Hi, I had this issue many times this week with this tool: On attached file, skin the 2 red profiles with the guides. ---> the resulting solid is damaged, looking transparent Check object + repair makes it correct.:) Why doesn'it repair on its own ? JL
Here's the file :
Bug skin guide.cu.zip
(84kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
