Originally Posted by: unique
What do you mean exactly ?
 Some clarification is in order.
1/ Opening the original file in a
clean copy of ViaCAD - I can blend edge B without a problem. On the other hand, holding shift and selecting edge B followed by edge A causes a problem (crash as described earlier). Selecting the edges in the order A followed by B does not cause a problem. I do the clean open before every test so there is no doubt of prior condition. (essential, if tedious, debugging practice).
2/ The crash is subtle, presumably depending on previous activity. However the above procedure is
repeatable. If I do one of the successful choices from 1/ above then use
undo things change! The crash might repeat or not, or it might be more dramatic. immediate exit without message.
3/ I cannot comment about the likelihood of the graphics groll being the culprit, because I know nothing about the software. All I know is that doing blending of complex shapes is a ....... I have examples that work and those that don't. I have a successful blend of guide_yoke.vc3, but only after many hours of work!
This thread is a great help. When I get to the bottom I will post my results.
