Thanks: 221 times Was thanked: 171 time(s) in 103 post(s)
I'm sorry, this has been reported many times :
Skin a solid with only 2 simple profiles : a circle and an ellipse...
It creates a buggy solid, looking transparent.
Using this solid in further boolean operations generates bugs & crashes.
---> I just lost one hour of work...
My usual workaround that I forgot this time was to stitch the solid.
But stitching the solid kills history...
Tim, help !
JL
Bug2.sfx
(17kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
I tried all the advanced options : none helpful ! Strange : unticking "Auto-Align sections" gives an error " "self intersecting or cusping surface found"... Cusping ?:confused:
Obviously size matters : With a bigger ellipse it works (multiplying the minor & the major dim by 10). Sorry, I do small things...:mad: JL
jlm wrote: Using this solid in further boolean operations generates bugs & crashes.
Just try to extrude one of the tip flat surface and boolean add it to the skinned section.
You see what I mean ?
JL
>>It creates a buggy solid, looking transparent. Repeated, found, and fixed in 788. >>But stitching the solid kills history... Stitching (not check object repair) creates a history item when you select an existing solid. When you select an existing solid, it repairs using current options setting. Tim
