#1 Posted : Monday, July 14, 2008 4:04:14 AM(UTC)
I'm sorry, this has been reported many times :
Skin a solid with only 2 simple profiles : a circle and an ellipse...
It creates a buggy solid, looking transparent.
Using this solid in further boolean operations generates bugs & crashes.
---> I just lost one hour of work...
My usual workaround that I forgot this time was to stitch the solid.
But stitching the solid kills history...
Tim, help !
JL
Bug2.sfx (17kb) downloaded 5 time(s).
#2 Posted : Monday, July 14, 2008 7:08:59 AM(UTC)
I tried all the advanced options : none helpful !
Strange : unticking "Auto-Align sections" gives an error " "self intersecting or cusping surface found"...
Cusping ?:confused:
#3 Posted : Monday, July 14, 2008 7:15:36 AM(UTC)
Obviously size matters :
With a bigger ellipse it works (multiplying the minor & the major dim by 10).
Sorry, I do small things...:mad:
JL
#4 Posted : Monday, July 14, 2008 7:25:30 AM(UTC)
Just try to extrude one of the tip flat surface and boolean add it to the skinned section.
You see what I mean ?
JL
#5 Posted : Monday, July 14, 2008 1:34:25 PM(UTC)
Repeated, found, and fixed in 788.
Stitching (not check object repair) creates a history item when you select an existing solid. When you select an existing solid, it repairs using current options setting.
