#1 Posted : Sunday, August 29, 2010 7:10:52 AM(UTC)
Was thanked: 173 time(s) in 105 post(s)
This has been mentioned several time but may be worth a separate post :
The tool isn't working with small gaps between two lines.
Without warning !
It creates too many bad profiles.
Thanks to have a look
JL
Bug trim.sfx (14kb) downloaded 5 time(s).
Capture d™©cran 2010-08-29 10.49.10.png (46kb) downloaded 0 time(s).
Jean-Francois Jacques
#2 Posted : Monday, August 30, 2010 9:25:45 AM(UTC)
Canada
Only one condition OverLap.
http://screencast.com/t/YWNhMzc0
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
#3 Posted : Tuesday, August 31, 2010 6:31:44 AM(UTC)
[/url]
Thanks for the video Jean Franois.
It's not so easy to elongate the lines when they are slightly angled (draft).
Another workaround is to do an inverted trim (with option key) to prolongate the short line.
It was working simple since vellum's time but the bug appeared with one of last year's updates...
JL
blowlamp
#4 Posted : Tuesday, August 31, 2010 7:23:25 AM(UTC)
blowlamp
This is from the Help feature near the top of the screen.
Martin.
#5 Posted : Tuesday, August 31, 2010 8:43:50 AM(UTC)
Canada
Blow, I forgot this one!!
But this Corner Trim Option Tool doesn't work with the JL's File.!!!
Tim, can you check this file?
#6 Posted : Tuesday, August 31, 2010 3:58:57 PM(UTC)
JL
Repeated and looking into!
#7 Posted : Wednesday, September 1, 2010 8:53:47 AM(UTC)
JL
Repeated found and fixed in 948. Many thanks for posting that example file!
Guest (5)
