Import/Export
Step export deforms surface (#4563)
Thanks: 233 times Was thanked: 184 time(s) in 111 post(s)
When I export and re-import the surface on the left, it gets deformed (on the right).
Bug export surface.sfx
(165kb) downloaded 5 time(s). Bug export surface.stp.zip
(5kb) downloaded 6 time(s). jlm attached the following image(s):
(55kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
I can't produce it. What's your system's configuration. See mines below.
Originally Posted by: rockyroad_us I can't produce it. What's your system's configuration. See mines below.
Today : SFX 1015 - Macbook pro 2.5 GHz Intel Core 2 Duo.
I don't think it's linked to the configuration. This kind of things happens on any of my computers...
Did you try to import my step file ?
JL
after import your step in my SharkFX.
(31kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
JL. Just so you don't think you're cracking up. I can confirm that I got the same thing as you when I tried your file yesterday... ...but today, it won't repeat :confused: Martin.
Hang on - possible solution :) When you Import this file, make sure you uncheck the Stitch Surfaces Into Solid option. On the other hand, if you Open the file, then it seems like ViaCAD/Shark does the the above automatically and you don't get the distortion. Martin.
First of all, the step file you posted appears to have two surfaces. You can see them when imported unstitched with different colors. When stitched checked, the two surfaces tend to combine thus you get that distortion.
Thanks Martin, Thanks Rocky ! It must be the tolerance when stitching... Tim ?
Import/Export
