#1 Posted : Sunday, July 10, 2011 5:22:02 AM(UTC)
This is an extremely old bug still on :
it is impossible to skin a small circle and a small ellipse.
See attached files
Bug skin.sfx (36kb) downloaded 5 time(s).
Capture d™©cran 2011-07-10 12.55.22.png (46kb) downloaded 0 time(s).
zumer
#2 Posted : Sunday, July 10, 2011 8:09:50 AM(UTC)
zumer
Cover surface closes the profiles, skin lofts between them. What's the issue?
rockyroad_us
#3 Posted : Sunday, July 10, 2011 4:41:08 PM(UTC)
rockyroad_us
Bug Confirmed. However, if you scale it by 10, skin solid and skin surface work. Something to do with the scale. You can always scale down for quick fix although it needs fixing.
posh.de
#4 Posted : Monday, July 11, 2011 6:33:02 AM(UTC)
posh.de
>...small...
means
circle : 0,2mm
ellipse : 0,7/0,4mm
#5 Posted : Monday, July 11, 2011 11:07:22 AM(UTC)
Fixed in next builds.
#6 Posted : Saturday, October 15, 2011 3:21:31 AM(UTC)
It is now working fine.
Thans Tim.
Minor detail : the edge doesn't display correctly, even with highest resolution.
See picture (yellow curve is supposed to be the solid edge...
Capture d™©cran 2011-10-15 11.18.15.png (128kb) downloaded 0 time(s).
Guest (5)
