#1 Posted : Sunday, September 11, 2011 8:51:48 AM(UTC)
This is an old and everyday enjoying bug :
Make 2 lines with a corner angle slightly higher than 90 (common case on plastic parts with draft to remove from mold).
Make a close parallel line (blue on sketch)
Impossible to use corner tool, unless the distance is sufficient (red line works).
See sketch and file
Bug gap corner.sfx (10kb) downloaded 5 time(s).
Capture d™©cran 2011-09-11 16.43.08.png (55kb) downloaded 0 time(s).
chipmaker2
#2 Posted : Sunday, September 11, 2011 3:30:22 PM(UTC)
chipmaker2
Hi jlm
I tried the corner tool with lines both .1 degrees + and - 1 degrees from 90 and it worked OK in ViaCad 2D V8. I was able to trim the line so there was no gap.
Notice the data window in the screen shot (In the attached file) up above shows the degree value of the selected line.
Chuck
chipmaker2 attached the following image(s):
Corner tool.jpg (59kb) downloaded 5 time(s).
#3 Posted : Sunday, September 11, 2011 4:32:45 PM(UTC)
Thanks Chuck,
Did you try to corner the lines on my example file ?
It is about small small gaps...
Or maybe it's just a Mac thing ??
JL
David Gross
#4 Posted : Monday, September 12, 2011 3:42:26 PM(UTC)
David Gross
It seems the blue lines are to CLOSE to "0" fillet for some reason, if you move the blue lines farther away they will trim just fine. Very strange.
David Gross
Dmg Design
Colgate, Wi.
chipmaker2
#5 Posted : Wednesday, September 14, 2011 12:43:31 PM(UTC)
chipmaker2
Originally Posted by: jlm Go to Quoted Post
Thanks Chuck,
JL
In the 2D V8 the corner tool worked on the red line to the left. The other gaps were to small. I could extend the other lines and so on. I could see where this problem could fool somebody into thinking they have a closed profile and then would have trouble using the extrude tool because of the opening.
I like using the region trim tool and I make a habit of crossing lines I use for profiles and then region trim them. I also make much use of the snap to "work plane" tool so all lines are on the same plane and will close up and trim.
Chuck
#6 Posted : Thursday, September 15, 2011 12:26:25 PM(UTC)
Fixed in builds 991.
Thanks for the example file!
