#1 Posted : Saturday, September 3, 2011 3:39:48 PM(UTC)
I received an eps file.
Opened with illustrator (I tried CS3 & CS5), then exported to DXF & DWG .
When I import in Shark FX, I get empty layers.
Saving it as AI gives a picture in Shark.
I want splines !
Archive.zip (432kb) downloaded 6 time(s).
#2 Posted : Saturday, September 3, 2011 3:50:00 PM(UTC)
Hi jlm
I imported into SFX the dxf file and checked the include paperspace box in the import window
the geometry is on a acad frozen layer so it came in locked
next unlocked the layers
it also came in as groups (acad blocks) so I ungrouped the geometry several times to get to lines and splines
catimportedfromdxf.sfx (1,436kb) downloaded 6 time(s).
#3 Posted : Sunday, September 4, 2011 8:06:49 AM(UTC)
Thank you Jason !
Are you on a PC ?
On my Mac it still doesn't work.
The DXF or DWG import is just empty (0 element in layers).
I could get the splines using illustrator version8 export - import...
CS3 or CS5 wouldn't work...
#4 Posted : Sunday, September 4, 2011 12:59:52 PM(UTC)
I just checked Mac, the dxf/dwg read in aok here as well.
What build are you using?
#5 Posted : Sunday, September 4, 2011 4:34:15 PM(UTC)
Build 968.
I tried open, import, drag & drop...
It always create empty layers.
Thanks Tim,
JL
Capture d™©cran 2011-09-05 00.32.03.png (29kb) downloaded 0 time(s).
#6 Posted : Tuesday, March 13, 2012 11:21:25 AM(UTC)
Was thanked: 111 time(s) in 73 post(s)
I have been getting empty imports of DXF meshes randomly in Shark LT 996 and even in SP1. Imports of 3D poly lines is fine, though.
VCP 7 opens the dxf files without problem. For now, I am having to open files in VCP 7, then saving as VCP, then opening the VCP with Shark LT and saving the file as SLT.
However, unlike (or similar?) JLM's issue, I get the collapsed tree, but all the nested layers are empty for imported DXF meshes.
Birger
#7 Posted : Tuesday, March 13, 2012 2:54:28 PM(UTC)
Birger
Norway
Was thanked: 10 time(s) in 4 post(s)
Try to move the DWG/DXF file to the desktop, then open SFX and import the file as DWG/DXF..
Hope it may help. - Dont ask me why if it does work all of a sudden. This is only a problem with DWG/ DXF files...
rgds
Birger
Eberhard
#8 Posted : Wednesday, March 14, 2012 10:55:11 AM(UTC)
Eberhard
On Mac, avoid special characters (Umlaut, accent, etc) in the path and name of the file. These cause DWG/DXF import failures.
Eberhard
#9 Posted : Friday, March 16, 2012 2:50:33 PM(UTC)
rgds
Birger
WhOAAAA....
What a minute... this is like a bug from the 90s, where when one had a file too deeply nested, then program would crash or not run the file...
#10 Posted : Friday, March 16, 2012 3:07:59 PM(UTC)
Sad to report... no joy...
I tried twice, and on the 2nd attempt, closed and reopened Shark...
I even truncated the file name to just 5 letters.
#11 Posted : Friday, March 16, 2012 3:38:16 PM(UTC)
Was thanked: 16 time(s) in 14 post(s)
File import fine en here, bot, shark fx v7 968 and shark v8 1003, the only thing is that after import, the geometry is hidden because the layer where is placed is hidden an locked, open your concept explorer, expand all the layers and, active their visibility and unlock them, then you must ungroup the logos to get the splines
Luis G.
[ATTACH]4317[/ATTACH]
MacOSX Sequoia 15.7.7
#12 Posted : Tuesday, March 20, 2012 3:43:22 PM(UTC)
In my display, there is nothing in the tree to expand.
Strangely, importing the file fails, but RAM consumption balloons to and remains at over 300MB until I process kill Shark.
This cannot continue. Please make a fix. For now, I am having to use VCP 7 to originate files, but now the video is acting just wonky enough that I have to save the files and open in Shark. As a safeguard, I now have two version a given parent DXF in Punch formats: one in VCP so I can get the DXFs having meshes, and a 2nd after I use the VCP file to generate a Shark SLT file.
#13 Posted : Monday, April 16, 2012 10:29:40 AM(UTC)
Hmph...
Pretty frustrating... The problem in my case is that my Freeship layers had asterisks in the names. I used them as flags to help me more quickly find certain types of geometry I assigned to separate layers. VCP has no problem *what*so*ever, but something in the Shark code base changed, and the users were not told.
May be insignificant to devs, but it puts users through agony. Some things users do due to code limitations or built-in "features"/'behavior are not that difficult to "guess at".
#14 Posted : Monday, April 16, 2012 3:17:40 PM(UTC)
this remain me that Once, I spend about two or three days trying to work with dwg file that won't be open, until i change an "" letter on the folder's name where the file was stored.
#15 Posted : Tuesday, April 17, 2012 1:29:24 PM(UTC)
DAMN DAMN DAMN me to hell.
I did *not* resolve my problem. It returned after rebooting. I suspect that something in RAM in concert with VCP and Shark being open may be "endowing" Shark LT with some ability to import the file. Well, that is my off-the-wall wish.
Later in the evening, I rebooted my computer (as suspend image was stale and the computer wouldn't properly suspend, forcing me to forcibly shut it down) and opened Freeship and edited a file. I later opened Shark LT to import some of the changes and SLT presented an empty layer.
I imported successfully some files from earlier in the day, so something in Freeship is editing text strings in the DXF. I suspect this because all I did was move a few control points around and change the mesh fineness in Freeship. This latter step of course adds far more mesh/vertex information to the DXF. I suspect that the file size is a moving target problem for SLT. FCP 7 has no problem. I don't yet have VCP 8 (I am assuming that since I upgraded to Shark LT V8, I should not go after VCP 8, right?), but I have no choice but to keep using VCP 7.
This morning, on a lark, I opened and snipped out huge chunks of the DXF file I renamed as .txt. This, as expected, produce a problem for both VCP 7 and SLT 8. Both apps imported NO geometry and both displayed the DXF file's name as a VCP and SLT layer name, with no content and no sub-level trees/branches.
I changed the file name length, and that did no good. I re-examined the Freeship layer names to verify I did not re-introduce any asterisk nor any "illegal" characters.
Guest (6)
