matty47
#1 Posted : Friday, October 10, 2008 11:53:29 PM(UTC)
matty47
Is there any way to move a vertex (eg corner of a plane) to a specified coordinate. I have not been able to work this out. I have a four corner plane and I want to specify where each corner is in the 3D world.
Using ViaCad 3D 6
Matthew
#2 Posted : Saturday, October 11, 2008 9:29:08 AM(UTC)
Using ViaCad 3D 6
Matthew
Select the vertex using the arrow tool. Then select Verify:XYZ. In this dialog box, you can also change the xyz to a new value.
