Filip
#1 Posted : Monday, September 23, 2013 2:52:31 PM(UTC)
Filip
I have a problem with 2D Model to Sheet. When I have 3D model and create in Shark Precise Curves I cannot get ARCs "lines". Model to Sheet create Splines.
Problem is because I cannot after that find Radial dimension or Angular dimension.
Do you find some solution for this problem?
zumer
#2 Posted : Tuesday, September 24, 2013 9:39:23 PM(UTC)
zumer
Checking 'simplify curves' in viewport properties might do what you want.
Filip
#3 Posted : Thursday, September 26, 2013 10:23:57 AM(UTC)
Filip
Thanks, but I will have then get lines.
And I will not be able to check angle.
zumer
#4 Posted : Thursday, September 26, 2013 4:58:34 PM(UTC)
zumer
Try 'flatten view'.
zumer
#5 Posted : Friday, September 27, 2013 6:24:58 PM(UTC)
zumer
Try "flatten view".
Filip
#6 Posted : Saturday, September 28, 2013 2:18:17 AM(UTC)
Filip
Thanks for interest.
I have attached IGES file in 3D. And I wish to create Model to Sheet and check Angle Dimension. But I get spliens. Propably there is no way to do this in easy way.
But Do you know if this is tool or somone create macro which able to check angle directly from 3D model?
RT6_250100-5-01.zip (1,060kb) downloaded 7 time(s).
Filip attached the following image(s):
memphisjed
#7 Posted : Saturday, September 28, 2013 7:42:08 AM(UTC)
memphisjed
Was thanked: 16 time(s) in 14 post(s)
Angle is dependent on point of view, guessing angle off a section in model2sheet? covert spline to arc (coolest tool in vc), or model to sheet with lines. vcp lacks precise, so this is default for me. Pull angle dim like normal, for radial dimensions draw 3 point arcs.
in example I pulled 2, one overall, one for upper half.
ViaCAD Pro (filip.pdf (62kb) downloaded 7 time(s).
Filip
#8 Posted : Saturday, September 28, 2013 2:03:43 PM(UTC)
Filip
Yes with added additionals lines, arc, it is possible to measure.
I also saw in one software direclty measurement from 3D model. Sometimes you open file and just want in the fastest way to see demension., angles etc.
