Filip
#1 Posted : Sunday, November 24, 2013 4:22:34 PM(UTC)
Filip
I would like to see one name in Concept Explorer after I would create e.g. Linear Duplicate.
After that I would like to have possibilty for easy change in Inspector.
Righ now we get a lot of part - and we cannot easily change patterns - we have to create usualy new one :( from begining
Filip attached the following image(s):
billbedford
#2 Posted : Monday, November 25, 2013 3:06:26 AM(UTC)
billbedford
Rename the part before you duplicate them.....
Filip
#3 Posted : Monday, November 25, 2013 11:12:12 AM(UTC)
Filip
You have not understand my problem. Maybe my English is not good...
I do not have problem with names of this all new parts.
I wish that in Concept Explorer was one object called e.g "Linear Duplicate"
After that you would click in this object "Linear Duplicate" and you could easily change number of new parts etc (All that you could do when you first time create linear pattern).
rockyroad_us
#4 Posted : Monday, November 25, 2013 10:36:44 PM(UTC)
rockyroad_us
I think he wants the logo changed so that the parts that were duplicated are different than just using the solid logo. I have that same issue when you got random patterns and you don't know which one is the original one for associativity. You sort of have to hunt for it.
billbedford
#5 Posted : Tuesday, November 26, 2013 4:09:45 AM(UTC)
billbedford
If you select any of the instances with the context menu you will be able to select the instance parent.
billbedford
#6 Posted : Tuesday, November 26, 2013 5:15:24 AM(UTC)
billbedford
Filip
#7 Posted : Tuesday, November 26, 2013 11:00:27 AM(UTC)
Filip
But we cannot reopen main Window- "Linear Duplicate" and add changes:
-Numbers
-Spacing
-Row Heigh
And I wish to have this possiblity in Concept Eplorer - This is what I suggest :)
In concept explorer should be name Linear Dupicate_1 after you click on it you should have this all function which you had when create firt time Linear Duplicate.
After I create pattern we can only do what shows screen bellow:
