Filip
#1 Posted : Friday, October 18, 2013 9:56:15 AM(UTC)
Filip
Do you know how to add shortcut for easy put mark ⌀ in dimensions?
L. Banasky
#2 Posted : Friday, October 18, 2013 5:33:51 PM(UTC)
L. Banasky
Was thanked: 148 time(s) in 102 post(s)
Hi Filip,
The only way I know of is to type ALT-0216 for a Diameter Symbol. Enclosed is a chart for other symbols.
#3 Posted : Friday, October 18, 2013 5:41:37 PM(UTC)
In mac es option+o or option+O capital
MacOSX Ventura 13.6.4
Filip
#4 Posted : Saturday, October 19, 2013 2:45:41 AM(UTC)
Filip
Thanks, I use PC.
If I use ALT0216 I do not get ⌀ but I get Ř
In my PC I can only use this marks. I have check and it works:
http://www.mrog.org/jak_wpisac_znak_na_klawiaturze.html
And from this page:
http://www.keepandshare.com/doc...r-ascii-codes-on-windows
All work beyond 224 till 255 :( - But inside this group is ⌀ :confused:
P.S.
This should works liku you worte L.Banasky but on my PC I cannot get good result. ?
http://www.fileformat.info/info/unicode/char/d8/index.htm
L. Banasky
#5 Posted : Saturday, October 19, 2013 3:48:09 AM(UTC)
L. Banasky
Hi Filip,
You could make a , and copy- paste. I like using SharkFX for modeling, but sorry to say, I have to export the Model-to-Sheet as a .dwg to AutoCAD LT98 for dimensioning. The Title block can be edited, arrowheads etc. are easy to change. I have tried over the years to use SharkFX, Concepts Unlimited,
Cobalt,and Vellum, and just can't put up with the frustration of dimensioning a drawing. AutoCAD LT98 is old, but it works, and finishes the paperwork.
#6 Posted : Saturday, October 19, 2013 6:35:46 AM(UTC)
Was thanked: 164 time(s) in 101 post(s)
I agree with Larry, text, dimensions and hatches are difficult to handle and there are many bugs....
Since Vellum 2.7 (~ 1995) the first real improvements I see on model to sheet are on beta V9, and they are promising...
Keep on hammering the nail Tim !
Filip
#7 Posted : Saturday, October 19, 2013 1:04:39 PM(UTC)
Filip
Thanks for interest of subject.
I hope Tim will read it and add some improvments :D
BobbyC.
#8 Posted : Wednesday, November 6, 2013 3:50:26 PM(UTC)
BobbyC.
One thing about using the ALT+ combo, you must use the numbers on the keypad, not the numbers above the letters. I know this is kind of old, but just wanted to throw that in.
memphisjed
#9 Posted : Monday, November 11, 2013 3:02:37 AM(UTC)
memphisjed
Was thanked: 9 time(s) in 8 post(s)
I guess I never thought about diameter symbol, and wondered why - doing (not drawing, doing) lots of holes, pipe saddles, and beams the last few weeks.
Drawings rarely have diameter, it seems radius is the normal (not a standard that I know, just a quick look over a stack). holes just say 7/8, 2 1/6 ect, if at all (usually x xx/16 u.n.o). Diameter is sometimes given in pipe rings by a linear demission across quadrants. Unless the drawings are in metric, which diameter seems standard and radius is not listed.
Having a CL symbol might be nice; everything is done off center. Yet another Tim genius moment having midpoint line.
I do know that dimensions seem to slow vcp to crawl almost instantly, so I generally reserve adding them at the very end, in a copy file - living my clean drawing clean.
Alan Bransom
#10 Posted : Friday, January 24, 2014 6:34:46 PM(UTC)
Alan Bransom
Hi Guys,
I'm running latest 2D3D on an iMac and dimensioning circles automatically puts the sign in. Placing it here was the standard Option + o.
Alan Bransom attached the following image(s):
Screen Shot 2014-01-25 at 11.27.32 am.jpg (116kb) downloaded 7 time(s).
jb2953
#11 Posted : Saturday, January 25, 2014 12:23:06 PM(UTC)
jb2953
If you are talking about a short key for diameter dimension you assign a key using the short cuts menu under file. You can assign a letter that gives you a short cut to radial out, radial in, diameter in, and diameter out.
Jim
