Does anybody know how use animation in Shark FX? Does anybody could share information how this all works? Any tutorial? I could not find any tutorials on youtube and here on forum also :( Thanks
I've done animation. It is a bit tedious but doable.
Could you share with it ?
or desribe how you have done it?
http://www.youtube.com/watch?v=qkL9ukPhoiQ I would like to make something much more advanced than on this video from above...
For example I tried to put three camera on grafic view.
But I could never make movie from it at one time. Record was always create from one camera :(
I tired to mark all three camera with "shift" or by "window"
I also would like that I could give the order of this camera which I had put on grafic view.
P.S.
While I will do it I will share wit it on youtube...
I assume you are going to follow a path. I have never tried moving the camera. My projects have been moving objects while the camera is fixed. I assume you can have the camera follow the path of the curve.
I know how to make that camera move. And I know how make easy one path with camera. But I do not know how exactly we could control more than one camera To add more than one camera I use function "Camera Animate" 1. I would like to put camera to few curves or splines. 1.1 Also to one long spline few camera objects 1.2 Here I need to get full control of this camera 2. I would like to choose which camera should record first , second ...(some sequence) 3. I would like to record in one movie those all camer`a path. Here I need sample or help how it works in Shark FX.. Any advice are welcome... Thanks
If you can do two or more cameras you can have the second one start at a different time. I wonder whether you can do more than one curve so that it changes scenery and just keep one camera.
thanks rockyroad_us for some advice.
Today I have work with those tools bellow - attached imagine.
I had added two camera to two separate curve and added different time like you wrote previously.
Now I get result which I wanted to get. Recorded was made from two camera.
I also added two Rotation Camera - and get some nice results.
But in my opinion would be also good to add those camera on place, now it is on time? -so it is hard to do in more advanced project...
Also those rotate camra sometimes had very huge FOV - I just wanted to get result like sombody would move his head to right but sometimes could not :(
I also tried to add Translate Camera- but do not understand yet how this works:(
Are there any people who work with animation and could share their observation... - would be helpful for all :)
Filip attached the following image(s):
(4kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
