Christophe
#1 Posted : Thursday, October 20, 2011 12:48:03 PM(UTC)
Christophe
Hello
I'm new in using ViaCad, thank you Tim to activate my account.
So far I managed all "problems".
My question is with the model to sheet, what is with the measurement's?
I have a model, that's transfered, but the dimensions are missing on the sheet.
The layer "dimensions" is always empty, what I'm dooing wrong?
Thanks for help
Christophe
la mouche
#2 Posted : Friday, October 21, 2011 4:19:27 AM(UTC)
la mouche
salut,
active the view window before to apply the dimension.
Antoine
Christophe
#3 Posted : Friday, October 21, 2011 12:50:37 PM(UTC)
Christophe
Salut aussi
Which View Window?
Christophe
Roger Barrette
#4 Posted : Monday, February 27, 2012 12:34:57 PM(UTC)
Roger Barrette
Hi Everybody,
Just wanted to know on how to have the dimensions go from the Model to sheet views without copy & paste.
PRP
#5 Posted : Monday, February 27, 2012 2:49:49 PM(UTC)
PRP
You do not need to dimension in 2D or 3D. Select your model and click on 'Model to Sheet'.
You will have 4 flattened views. Click on one of them and you'll get a dotted red outline. That is the "view window". When in a view window you can use the dimensioning tools.
Roger Barrette
#6 Posted : Monday, February 27, 2012 3:54:10 PM(UTC)
Roger Barrette
Ok, I did that once, but I thought if you dimensioned in your model it would go automatically to your sht view.
Thank you
