Suggestions
enable architectural entities for MTS (#3302)
Bring 2D walls/doors/windows into a scalable draw view correct? FYI, for typical MTS templates several of the default views of this 2d data would be on edge. Tim
Originally Posted by: Tim Olson Bring 2D walls/doors/windows into a scalable draw view correct? FYI, for typical MTS templates several of the default views of this 2d data would be on edge. Tim
How about a new MTS icon for Architectural Tools that sends the drawing you made with the wall/door/window tools to a sheet with a single top view.
The wall tools are really useful for drawing floor plans, you've given us a very handy tool set there Tim. It just needs a bit more love! :D
Surely, most people who care to use these tools then need to then put their finished floor plan on to a drawing sheet? At the moment you can only do it manually by copy/paste into a draw view and how to do that isn't as obvious as it might sound. :)
Yes I would agree that having model to sheet option for 2d objects like polygons, and architectural objects would be nice. 1. The scaling would be super easy. 2. Detail views would be easy to work with as well. Regards Jason
yes
Originally Posted by: Tim Olson FYI, for typical MTS templates...
should not have used MTS, meant draw view.
it's [URL="http://forum.punchcad.com/showthread.php?t=3308"]his request[/URL].
Norbert
Suggestions
