Redss
#1 Posted : Saturday, December 13, 2008 11:47:14 AM(UTC)
Redss
I would like to see what Screen Resolution everyone uses.
I made the Brass Wine Rack in ViaCad-6 and put it into my e-Cabinets program as a STL File:D
Redss attached the following image(s):
EC Program.jpg (139kb) downloaded 0 time(s).
nick
#2 Posted : Sunday, December 14, 2008 1:49:09 AM(UTC)
nick
Hello Redss
The screen resolution you use all depends upon the size of your monitor, as a rule of thumb the larger the monitor the larger the resolution supported. I use 1920 x 1200 with 24" monitor and 1280 x 800 with 13.3".
All the best
Nick
Redss
#3 Posted : Sunday, December 14, 2008 8:36:39 AM(UTC)
Redss
Thank You Nick
That is a big help for me:D
Redss
#4 Posted : Sunday, December 14, 2008 12:03:59 PM(UTC)
Redss
Hi Nick
My 2 They look like 1-19"_1-16"
I change the 18" to 1152-864
When I loaded ViaCad-6 on to the new Del llast night
Here is what happen to ViaCad-6 I can not move the top left down
It should be.I tryed to fix it last night before I change to (1152-864) today I looked all over in help? Did I over look it?
I reloaded it 2- times last night.
Thank You and everyone's help
Redss
nick
#5 Posted : Sunday, December 14, 2008 12:33:41 PM(UTC)
nick
Hello Redss
This is a common issue when switching resolutions, if you select a vertical resolution smaller than the height of the main tool bar then the tool bar header is shifted off screen. If you cannot correct by using Factory Page button in General section of Preferences then you need to do the following:
1. Open your VC3Prefs.ini file in a text editor such as notepad
2. Find the [PalletPositions] section of your VC3Prefs.ini file.
3. Change the line ToolBar Popup=XXX,XXX where XXX & XXX are co-ordinate position in pixels of top left corner of tool bar. For example my main toolbar has co-ordinates 0,109 so it is 0 pixels across and 109 pixels down from the top left hand corner of screen.
Hope this helps.
All the best
Nick
Redss
#6 Posted : Sunday, December 14, 2008 1:09:37 PM(UTC)
Redss
Thank You Nick
I was just getting ready to try it.
The bass came into the office said what are you doing.
She said get out of the chair she fixed it in 1/2 Sec.She opened it and did something and it is OK now.I gauss I will have to keep here around another (YEAR):D
