Import/Export
Unable to load SketchUpReader.dll, atl71.dll (#3729)
I still can not open any SketchUp in ViaCAD Pro v6
I have not been on the web. for about 6 months now.
I need to get to SketchUp files I have a customer that made his plan in SketchUp
I do not like useing it I would like to put it in ViaCAD Pro v6 then I can work on this plan. To me ViaCAD is a lot easier for me to use.I did ask before if anyone could help Tim Olson did come and try to help me put then I got sick :(
I did try what he said to do but it did not help.Would there be something I could try :confused:
Redss
Redss attached the following image(s):
(49kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Hi Redss Do you have an older version of ViaCAD 2d/3d to try to open the file in? Then you could save and open in ViaCAD Pro. Regards Jason
Hi jdi000
I reloaded a older version of ViaCAD 2d/3d it does the same thing.
I am not sure when I lost the Sketchup file. I think when I upgraded to Windows 7 Professional is when I think I lost it.
I have 2 screens that I use when going into my rendering library. I originally had 2nd screen on the right side of 1st screen and everything was fine, I then moved the 2nd screen to the left side of 1st screen and that is when I noticed it was not working. You do see the library loading but don't know where it goes to.
Thank You so much for your help jdi000
(59kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Import/Export
