Suggestions
Object Info Dialog Box - Add Curve Direction/Reverse (#2456)
                Tim, can we add to the Object Info dialog box, on the Attributes Page settings to toggle the view curve direction command. Also add the ability to reverse the direction if needed from this box. GK
                Originally Posted by: Glenn Karnish  Tim, can we add to the Object Info dialog box, on the Attributes Page settings to toggle the view curve direction command. Also add the ability to reverse the direction if needed from this box. GK
Glenn,
I added this in the right button in Shark V6.
    Tim Olson  IMSI Design/Encore
Suggestions
