giulioandrea
#1 Posted : Monday, July 30, 2007 12:39:39 PM(UTC)
giulioandrea
Is there a way to fix a 'corrupted file'?
It happened to me already twice to have a model trashed because of this error.
Fortunately I am keeping copies of the 3d with incremental versions and when this happens I do not loose too much...
... generally :-(
Just the last bit I did over the weekend is now corrupted...
The error which just blink is 'invalid work plane'
Any idea?
The Mac and disk are both fine.
Ought to be something else... Perhaps a bug?
Ciao,
G.
nick
#2 Posted : Monday, July 30, 2007 3:03:10 PM(UTC)
nick
Hello G
Concepts or ViaCAD? Can you post copy of file?
All the best
Nick
giulioandrea
#3 Posted : Monday, July 30, 2007 4:22:02 PM(UTC)
giulioandrea
unfortunately I cannot post it.
but it is Viacad.
It does not open the file.
it just say damaged and for just a second an error indication about the work plane.
g.
nick
#4 Posted : Tuesday, July 31, 2007 3:37:58 AM(UTC)
nick
Not sure if this will help with ViaCAD but set your display mode to wireframe and then import the file as opposed to opening it.
All the best
Nick
giulioandrea
#5 Posted : Tuesday, July 31, 2007 4:47:35 PM(UTC)
giulioandrea
Nick,
no luck...
again:
'The file is damaged, cannot read into application'
and on the top left:
'Error reading work plane'
which sounds really sad... since probably the geometry is fine...
ooops!
g.
