giulioandrea
#1 Posted : Sunday, July 15, 2007 2:30:49 PM(UTC)
giulioandrea
how to draw a normal at the end of a spline?
hot to draw a tangent line starting precisely at the end of a spline?
which snap to use?
thanks
G.
#2 Posted : Sunday, July 15, 2007 4:55:05 PM(UTC)
Was thanked: 171 time(s) in 103 post(s)
Hi giulioandrea,
That's an easy one :
Select your spline,
show control points (command-D, or object info panel),
Use the end vector points to draw a tangent line (change length & direction if necessary).
Draw a perp to this tangent if you want a normal;)
Have fun !
JL
giulioandrea
#3 Posted : Monday, July 16, 2007 6:55:22 AM(UTC)
giulioandrea
I actually hoped to find a more cursor based technique. But in the end it's the result that matters.
Thanks a lot for your help!
Ciao
G.
