lovebugjunkie
#1 Posted : Monday, January 3, 2011 1:22:13 PM(UTC)
lovebugjunkie
Found the tips on Shark Attack very easy and informative as a new user, any chance in having them once or twice a month?
#2 Posted : Tuesday, January 4, 2011 1:08:58 PM(UTC)
I added another entry today to the blog regarding Object Resolutions.
http://blog.punchcad.com/?p=445#more-445
lovebugjunkie
#3 Posted : Tuesday, January 4, 2011 1:48:29 PM(UTC)
lovebugjunkie
Thanks you for taking the time for this type of info. Found it very interesting as a new user.
#4 Posted : Tuesday, January 4, 2011 2:12:27 PM(UTC)
Tim, you say that 'fine' uses an angular deviation of 11 degrees. Then you go on to say 'medium' uses an ang dev of 11 degrees in your table
#5 Posted : Tuesday, January 4, 2011 3:04:07 PM(UTC)
Fixed, thanks for the heads up!
misterrogers
#6 Posted : Monday, January 10, 2011 7:40:59 PM(UTC)
misterrogers
Tim, not sure if these Shark Attack tips are made by yourself or others, but I would really like to see extended tips on all the Constraint tools (some have been made by Mikeschn) .
Also I am not familiar with the following Surface tools. Any sort of basic demo of them will be very valuable.
Thanks.
misterrogers attached the following image(s):
