capngene
#1 Posted : Thursday, September 2, 2010 7:27:51 AM(UTC)
capngene
MAC Powerbook G4, OS 10.5.8
Shark V5
I did the following:
1 Create 2D of trapazoidal sheet with constraints
2 Go to 3D, select the Lines of the perimeter of the sheet
3 Extrude to random thickness and change to proper thickness of .063 in control panel
4 Make Instance copy off extruded sheet, call it Top1 and put it in a new layer named Top
So far, everything is fine. I change a controlling dimension and it flows through everything.:)
5 Save the file using Save As and put it in a new job folder
6 Quit Shark
7 Re-open shark after several hours ans session with Cobalt, quitting Cobalt before opening.
8 The only things in the file are the 2D constrained lines. Everything else is gone although the layers are there.:eek:
What did I do wrong.:confused:
idrawdreams
#2 Posted : Thursday, September 2, 2010 2:27:14 PM(UTC)
idrawdreams
ViaCAD 2D/3D V7 exhibits a similar behavior in that if a 3D drawing is opened into a 2D environment, all that will be visible is the 2D components. I shut down, restart, and select 3D environment, then open 3D my drawing. Granted, Shark is a different breed of cat, but give it a try.
capngene
#3 Posted : Thursday, September 2, 2010 3:42:00 PM(UTC)
capngene
Thanks Richard,
It seems to work if I select 3D before opening my drawing.
