Crash when printing (#3441)
when I try to print a "model to sheet" view in a shaded option (flat, phong...), tha Viacad application crashes. It doesn't matter how complex the picture is.
In flatline option, printing works.
OSX 10.6.4, Viacad 936, Minolta 2350 Postscript Printer. Any Idea? A attached the crashlog. It says:
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000031af20c8
An other bug (I think) is, that the manual placement for block diagonals primitive fails: Entering x,y coordinates in the fields at the top of the screen has no effect, the bock diagonals primitive insists on using the origin. By comparison, the ellipsoid and torus are both placed according to the data in the fields.
Thank you.
Ohne Titel.txt
(43kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Honest question: Am I in the correct forum category? Thanks.
Hi Berzerk The printing is fixed in subsequent builds. This is ok forum category Regards Jason
