septemous
#1 Posted : Thursday, May 31, 2012 5:16:08 PM(UTC)
septemous
I'm in 2d/3d v8 sp1
Is there a way to select by name? I've made an array for punching holes - but it is difficult to select each of the 60 cutouts. Wonder if there is a way to do this more simply?
Would like to just select all the curves via select box - extrude then cut.
Thank you
S_
#2 Posted : Thursday, May 31, 2012 5:39:34 PM(UTC)
Hi S
Maybe try the selection mask in the window menu.
select mask.PNG (7kb) downloaded 5 time(s).
septemous
#3 Posted : Thursday, May 31, 2012 6:23:09 PM(UTC)
septemous
Did the trick - bit of luck as my object were selectable like that - but hey it worked :)
