Ed Kocia
#1 Posted : Monday, June 2, 2008 8:32:02 PM(UTC)
Ed Kocia
Thought I'd post a ViaCAD rendered model. I was just trying to see what could be done without surface trimming tool
Ed
Ed Kocia attached the following image(s):
#2 Posted : Tuesday, June 3, 2008 12:13:45 AM(UTC)
Ed
Very nice ED, thanks for posting! Is this all surfaces (no solids)?
Without the trim surface tool your used to, you are limited to imprinting curves on surfaces and exploding or stitching everything into solids and then using booleans.
Ed Kocia
#3 Posted : Tuesday, June 3, 2008 4:39:52 AM(UTC)
Ed Kocia
Tim,
It's a solid. I broke off the glass so I could make them transparent. I used surfaces to trim solids, or to make stitched solids to join to other solids. It is amazing what can be done if you carefully plot out your design course.
FYI. For those not framiliar with the plane, it was designed for bomber support. It's wings folded and it was to be carried on a telescoping support in the belly of a B-36. Hence it's pudgy demeanor. Launches went well, recovery didn't
Ed
#4 Posted : Tuesday, June 3, 2008 5:01:36 AM(UTC)
Ed .. what a mad looking plane
I wouldn't have believed it without the pic .. thanks for that !
#5 Posted : Tuesday, June 3, 2008 11:39:32 AM(UTC)
Was thanked: 177 time(s) in 107 post(s)
Yes, and it must have been a mad feeling to sit inside a reactor...
