danieladro
#1 Posted : Wednesday, April 11, 2007 5:18:48 AM(UTC)
danieladro
Hello all.
Am i the only one who feels that ViaCAD is somewhat sluggish when panning and zooming the drawing? I am not using a very complex drawing of anything (just a 2D imported from a DWG with 300KB), but, for me, it seems to slow to be usable! I already wrote tech support and sent the file in, but just wanted to know the general impression all of you have with the program.
My computer is a macbookpro coreduo 2.0, with 2 gigs of ram, so i would expect it to work smoothly.
On the plus side, i enjoy the interface and the mechanic of the program, and hope this situation can be solved so i can keep working with it! :)
Cheers.
NickB
#2 Posted : Wednesday, April 11, 2007 11:32:31 AM(UTC)
NickB
How are you viewing your files ?
Any setting with hidden lines on is incredibly slow on a mac and almost unusable. Generally I try not to ever use these modes and stick to full wire frame (no dimming or hidden lines), or shaded.
Shark FX 9 build 1143
OS X 9.5
matter.cc
danieladro
#3 Posted : Wednesday, April 11, 2007 1:30:00 PM(UTC)
danieladro
No, i am drawing in 2D, so no options to render. And the drawings are quite simple, with little over 300KB in dwg format.
#4 Posted : Wednesday, April 11, 2007 9:18:23 PM(UTC)
We've got a plan to address this issue using some opengl technology from the home design products.
#5 Posted : Wednesday, April 11, 2007 9:20:29 PM(UTC)
Do you have drawing views? (Use Verify:Object Counts) and search for Drawing Views in the list. If so, try exploding the draw views to see if that speeds up your display.
danieladro
#6 Posted : Monday, April 23, 2007 10:08:39 AM(UTC)
danieladro
Hi. Thanks for your attention to this matter.
No, i don't have any drawing views. Anymore suggestions?
