DPM
#1 Posted : Wednesday, August 8, 2012 7:55:37 AM(UTC)
DPM
Right now my center lines keep coming up a nice bright neon green ....AND I CAN"T STAND IT ANY LONGER..... in the concept explorer the center line is to be blue, under pen (properties) and other properties (attributed) in the inspector blue has been selected. Does anyone have suggestions on how to change the color of my center line from NEON GREEN to blue?
Roger Barrette
#2 Posted : Friday, September 21, 2012 1:54:02 PM(UTC)
Roger Barrette
Select the line
Go to your Inspector Box, Pen Properties
Then use the color drop down menu & select your color
macnavi
#3 Posted : Sunday, September 23, 2012 10:52:53 PM(UTC)
macnavi
Netherlands
If you do the same thing WITHOUT selecting the line, all your next lines will have that new colour.
There are two panes in the Inspector where you can choose the colour. The second pane is the line colour, the third pane is the fill colour.
