David Gross
#1 Posted : Wednesday, June 27, 2007 1:52:05 PM(UTC)
David Gross
There is a sheet view in this file that I can't seem to export to a R13 Autocad file. this happens to me a lot. I import all my parts into Concepts and split them into cavity and core. I really depend on CU for my 2d line work. I hope its a bug and not something I'm doing.
David Gross
Dmg Design
Colgate, Wi.
David Gross
#2 Posted : Wednesday, June 27, 2007 1:56:38 PM(UTC)
David Gross
I guess the file didn't make it.
David Gross
Dmg Design
Colgate, Wi.
nick
#3 Posted : Wednesday, June 27, 2007 2:18:16 PM(UTC)
nick
Hello David
Try compressing the file as .zip before uploading, forum only accepts certain file types as valid attachments.
All the best
Nick
David Gross
#4 Posted : Wednesday, June 27, 2007 4:19:09 PM(UTC)
David Gross
Tried a zip and a .cu no luck
David Gross
Dmg Design
Colgate, Wi.
David Gross
#5 Posted : Wednesday, June 27, 2007 5:24:14 PM(UTC)
David Gross
I guess I can't export a dwg or upload a file. That sucks
David Gross
Dmg Design
Colgate, Wi.
nick
#6 Posted : Thursday, June 28, 2007 3:30:02 PM(UTC)
nick
Hello David
Email me a copy of the file you are trying to export and I'll take a look. My email address is nickcadsoftsolutions.co.uk
All the best
Nick
#7 Posted : Thursday, June 28, 2007 9:46:50 PM(UTC)
I think there is a 10MB file limit, so check your file size. I uploaded a .cu file the other day fine. You might also want to try zipping it.
Also, when you upload a file to the forum be sure to follow all the prompts. The first time I did it I missed the submit button on the lower part of the page.
David Gross
#8 Posted : Friday, June 29, 2007 7:14:26 AM(UTC)
David Gross
My file is 1.6 meg's and when I upload it I keep getting an error message. Here are a few lines of what it says.
There seems to have been a problem with the Punch! Cad Forums database.
Please try again by clicking the Refresh button in your web browser.
An E-Mail has been dispatched to our Technical Staff, whom you can also contact if the problem persists.
We apologise for any inconvenience.
q}:~C]S\r~]GRQS\0so;K:yw\0\r\Zq]\"m©x=\06 g>xx
David Gross
Dmg Design
Colgate, Wi.
#9 Posted : Friday, June 29, 2007 2:09:28 PM(UTC)
David,
Private email me the file you cannot export to DWG.
#10 Posted : Monday, July 2, 2007 10:04:56 AM(UTC)
David,
Repeats here as well. The problem is related to Part 503644 being embedded inside the DWG. ACIS is crashing converting the part from R16 to R7. I've sent off to Spatial. Can you share this part as a STEP file until we hear something back from Spatial?
David Gross
#11 Posted : Monday, July 2, 2007 1:12:33 PM(UTC)
David Gross
I did get the 2d out by flattening the view and using the iges export.
David Gross
Dmg Design
Colgate, Wi.
#12 Posted : Monday, July 2, 2007 2:33:46 PM(UTC)
Ok. Spatial confirmed today that it is a bug and working on a fix.
