Anyone familiar with these guys and their rendering products?
Brian Graham Mac OS Sequoia 15.4.1 Mac mini 2024 Apple M4 24GB 1TB SSD Shark FXv 15 Build 1722
Hi grahamdesign I have played around with Hypershot and personally, I think it is a "love it or hate it" type. For use with a product, where a nice render of the product on a simplified background is required with no need for a degree in lighting is needed, then yes, very nice. But for a "all-round" renderer, in which I mean I could also have my landscape scenes rendered, then no, I would want/need far more control over the environment lighting. - Steve
I have found some of the renders I made while testing, so have attached one where I was testing the default glass shaders.
(324kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Wow - great rendering ! Incidentally, what's your molding methodology for that part : )
Perhaps a Stereo Lithography only part !?
Hi Jol
Originally Posted by: jol Incidentally, what's your molding methodology for that part : )
It was just a model of a double-moebius I built, really just for the fun of it.
- Steve
You can stop working it out Paul, I was just kidding !
Thanks: 140 times Was thanked: 124 time(s) in 84 post(s)
Has anyone modeled the Mbius strip in Viacad? Got a model you can share? Mike...
Originally Posted by: mikeschn Has anyone modeled the Mbius strip in Viacad? Got a model you can share? Mike...
Mike
I added a Klein bottle to the import spline examples. A Klein bottle can be produced by gluing two Mbius strips together along their edges.
http://forum.punchcad.com/showthread.php?t=84 Attached is an example using the mobius equations. Download the attached file and read into ViaCAD or Shark using the File:Import:Splines option.
mobius.txt
(1kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: ZeroLengthCurve You did that in ViaCAD?
Yes. VC 2d/3d
Hi Tim
Originally Posted by: Tim Olson Attached is an example using the mobius equations. Download the attached file and read into ViaCAD or Shark using the File:Import:Splines option.
I was just looking at this. I see that the surface is not closed (there is a gap) was this intentional so as not to receive the "Self intersecting or cusping surface found"?
I remember seeing a post from you mentioning a change in program to allow this,.. is this now implemented?
- Steve
Has anyone managed to use Bunkspeed with a Mac
