radler64
#1 Posted : Tuesday, January 17, 2012 2:22:10 AM(UTC)
radler64
Hello,
I have this problem now since days and can't solve it. I am new with Shark FX in general and I am using Version 8.
What did I do?
1. Imported a DXF from my previous 2D CAD solution.
2. Removed some pieces from the drawing. And there are still some pieces in layers which are hidden right now.
3. I made sure, that the whole contour line is one single line. See the picture attached, I was able to hatch it.
4. Now I am trying to extrude it with "Extrude Solid" and I am getting the "Gap detected.." message.
I can not find where the gap should be. So what can I do to extrude it finally and continue with the rest of the work.
Any advice is appreciated.
Thanks for your help.
Dieter
radler64 attached the following image(s):
Screen Shot 2012-01-17 at 9.14.43 AM.jpg (152kb) downloaded 4 time(s).
L. Banasky
#2 Posted : Tuesday, January 17, 2012 3:27:33 AM(UTC)
L. Banasky
Was thanked: 158 time(s) in 108 post(s)
Hi Dieter,
I also have this problem with imported .DXF files. I can't explain how it works, but if I erase a line or 2 and redraw the lines, especially at the end of a radius, the file will extrude. Try this on the file without any hatching.
blowlamp
#3 Posted : Tuesday, January 17, 2012 3:40:08 AM(UTC)
blowlamp
As Larry says, try excluding the Hatching in the Extrusion.
Martin.
radler64
#4 Posted : Tuesday, January 17, 2012 6:44:31 AM(UTC)
radler64
Originally Posted by: L. Banasky Go to Quoted Post
Hi Dieter,
I did what you've suggested - and it worked.
I deleted one of the radius and recreated the line.
And I can extrude it now.
Thanks to both of you for the quick help.
Best regards
Dieter
Screen Shot 2012-01-12 at 1.50.54 PM.jpg (18kb) downloaded 4 time(s).
