dexter
#1 Posted : Tuesday, August 7, 2007 6:14:09 AM(UTC)
dexter
When I save a Hidden Line view to Adobe Illustrator format, I expect the hidden lines to not show up. Is this a bug, or am I missing something?
Quick search of this forum didn't show anything up similar.
Dexter
ViaCAD 711, Mac OS X 10.4.10
giulioandrea
#2 Posted : Tuesday, August 7, 2007 8:17:37 AM(UTC)
giulioandrea
Same problem for me in the sheet generation.
I guess it is a general bug.
Have you got solids or surfaces?
For me the problem was specific to surfaces. Solids worked ok...
Hope for a fix.
G.
dexter
#3 Posted : Tuesday, August 7, 2007 9:34:21 AM(UTC)
dexter
Mine are solids... :)
They have a fix coming for some Model to Sheet display issues - perhaps this is something related.
giulioandrea
#4 Posted : Wednesday, August 8, 2007 4:47:01 PM(UTC)
giulioandrea
tried the same here.
what happens to me is that the solids are exported with visible lines only but all the solids are visible... so if something is in front of something else you see both...
see image for explanation.
so basically it does not work here as well.
g.
[ATTACH]116[/ATTACH]
Picture 1.png.zip (75kb) downloaded 5 time(s).
