3 Pages<123
24c
#41 Posted : Wednesday, November 18, 2026 2:55:20 PM(UTC)
24c
Was thanked: 96 time(s) in 64 post(s)
Just an interesting add to this conversation…
Solidcraft has now got plug ins, from version 0.44
Quick YT link to see a gear plug in
It is impressive how this is developing so quickly, as is PhysCAD, and both respond well to user feedback.
Mike
macOS Tahoe-v17 beta b1908
24c
#42 Posted : Wednesday, November 18, 2026 3:52:11 PM(UTC)
24c
Another one, works in your browser… early days but just posting for reference, does have a CAM package too
CADivari
Opened pretty fast in Safari on macOS, just going try and edit a STEP file**
Mike
PS, it can’t do that** pretty limiting, but might be useful.
Edited by user Wednesday, November 18, 2026 3:55:29 PM(UTC)  | Reason: Doesn’t import STEP
#43 Posted : Thursday, November 19, 2026 11:39:16 AM(UTC)
Was thanked: 267 time(s) in 175 post(s)
Of all the alternative CAD programs, Plasticity is simply the best and the most intuitive to use. It also has better snapping capabilities and automatic guide lines than SharkCAD. I bought it when it was recommended here.
GARLIC on 11/19/2026(UTC)
relaxibus
#44 Posted : Friday, November 20, 2026 2:24:24 AM(UTC)
relaxibus
Was thanked: 93 time(s) in 53 post(s)
I invited Mike from PhysCAD to join the forum:
Hi Mike,
the PunchCAD users desperately are looking for an ViaCAD and SharkCAD alternative. This are one of the best useable tools (not to compare with Fusion, etc), but it's still bugy, slow (no native Apple Silicon and Metal) and we don't know what happens in future after Mac Rosetta will be depleted.
https://www.punchcad.com
You could join our conversation on https://forum.punchcad.c...ts&m=43804#post43804
and give some insight of your CAD and read what users are looking for.
Mikes (PhysCAD) answer:
Thank you Jarno! This is great to know, and sounds like just the thing this was built for. I will try and hop on when I can, but to be honest, we are slammed with development work at the moment, so my free time is very limited. My suggestion is to have some of those folks jump on our discord server, that's the easiest way for me to handle feature requests at the moment. https://discord.gg/fev2VpyPWW
forwarding this to ryan as well, as maybe he can jump on the forum and get the low down as well.
relaxibus
#45 Posted : Friday, November 20, 2026 2:29:33 AM(UTC)
relaxibus
But how do you handle modifications? E.g. you need to move a hole, or to modify a fillet/chamfer? I used Vectorworks in the past when it was no parametric, a nightmare.
So can you use Plasticity as a Shark alternative?
Edit: No DXF/DWG import for Mac?? This is a annoying!
Edited by user Friday, November 20, 2026 5:45:08 AM(UTC)  | Reason: Not specified
thanks 1 user thanked relaxibus for this useful post.
MPSchmied on 11/20/2026(UTC)
#46 Posted : Friday, November 20, 2026 1:41:32 PM(UTC)
Sure, Plasticity doesn't have all the features I need either. But I prefer Plasticity's Drafting Assistant (LogiCursor) over the one in Shark.
And you can move holes: Select the inner face of the hole and press G. This brings up a kind of gizmo that you can use to move the hole.
Quote:
Moving an Existing Hole in Plasticity
There is actually a direct way to do this. In Plasticity 2025.3, moving circular edges on solid bodies was also improved.
Step-by-step instructions
  1. Open your model in Plasticity.
  2. Press 3 to switch to Face Selection mode.
  3. Select the cylindrical inner face of the hole.
  4. Press G to activate the Move tool.
  5. Move the hole along the desired axis using the gizmo, or enter a precise displacement value.
  6. Confirm the operation.
Alternative method (Plasticity 2025.3 and later)
Press 2 to switch to Edge Selection mode, select a circular edge of the hole, and press G to move it.
For complex holes, the surrounding geometry may limit what modifications are possible.
This method is intended for repositioning an existing hole in a solid body, not merely moving a circle in a sketch.
Edited by user Friday, November 20, 2026 1:58:19 PM(UTC)  | Reason: Not specified
GARLIC on 11/20/2026(UTC)
3 Pages<123
