Thanks: 1 times Was thanked: 4 time(s) in 4 post(s)
Is there any timeframe for a version of SharkCAD that's compatible with macOS 27?
Thanks: 3 times Was thanked: 10 time(s) in 9 post(s)
As posted elsewhere V17 does seem to be compatible with MacOS 27.
1 user thanked Claus3 for this useful post.
I think the question is not that it's compatible with macOS 27 but when is there going to be a Mac Silicon version of ViaCAD, not the Rosetta-requiring Intel coded version. Rosetta only has a limited life now that Intel Macs have been dropped from support by Apple, so if there is no Mac Silicon version of ViaCAD available, it is a waste of money upgrading in the future. Apple Silicon computers were first release in November 2020, so it almost 6 years since Intel processors were replaced in their computers.
I have the same question - without a native Apple Silicon version of ViaCAD, I will have to switch my engineering design work to another program.
Edited by user Saturday, September 19, 2026 8:56:20 PM(UTC)
| Reason: additional point and question
Rosetta2 is removed from macOS27. If SharkCAD needs rosetta2 to run and is not fully mac silicon compliant then it won't run on macOS27.
Originally Posted by: Albatrossflyer Rosetta2 is removed from macOS27. If SharkCAD needs rosetta2 to run and is not fully mac silicon compliant then it won't run on macOS27.
Not quite - Rosetta is still installable as an additional download for macOS 27, but is no longer included in the OS download. I have installed it to run ViaCAD V17. It slows the performance markedly and crashes the app on exits at irregular times, but you can still use it.
We
REALLY NEED a native Apple Silicon version of ViaCAD and soon. Rosetta is definitely gone for the next macOS update.
1 user thanked Publish for this useful post.
Thanks: 16 times Was thanked: 7 time(s) in 4 post(s)
Hello. I'm working since few days with last version of MasOS + V17 for some simple projects. No big problem until now.
Thanks: 6 times Was thanked: 7 time(s) in 6 post(s)
no problem SharkCad 16 is running with MacosX 27 on m my iMac M1
best wishes Andreas since ViaCad 5 with punch, now > SharkCad 16 , Mac
1 user thanked andreaswieneke for this useful post.
