Suggestions
Fix the old Bug Skewed "Bounding Box"
Thanks: 327 times Was thanked: 208 time(s) in 144 post(s)
If an object does run parallel to the base surface but not quite to the y-axis, and you therefore create a work plane perpendicular to the centerline and then create a bounding box, then the bounding box becomes skewed. I noticed that when I wanted to trim something with a makeshift template and it failed with this pipe.
(138kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 10 times Was thanked: 37 time(s) in 23 post(s)
Hi MP,
It looks like you did a cutout of the pipe and the cutout was not perpendicular to the pipe.
Look at the 2 red stripes in my image.
If I draw a construction line below it is parallel with the line above so it looks like that the cutout was not perpendicular with the pipe..?
And when did you draw the bounding box, before or after you created the work plane?
Edited by user Monday, June 8, 2026 10:01:24 AM(UTC)
Theo5715 attached the following image(s):
(14kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
If things don't go the way you would find a way it could. Win11-Intel Core i7-9700K CPU @ 3.60GHz RAM-32GB Shark14&Powerpack
Suggestions
