SharkCAD 16 Pro Upgrade from SharkCAD Pro 15 Mac
Hey everyone,
Edited by user Friday, April 18, 2025 8:41:20 PM(UTC)
(277kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Brian Graham Mac OS Sequoia 15.4.1 Mac mini 2024 Apple M4 24GB 1TB SSD Shark FXv 15 Build 1722
Thanks: 327 times Was thanked: 206 time(s) in 143 post(s)
Originally Posted by: grahamdesign Is there a version 16?
No.
https://www.punchcad.com/product-line-comparison OS: Windows 10 | CPU: AMD Ryzen 7 2700 | RAM: 32 GB | Graphic: AMD Radeon RX 7900 XT | SharkCAD 15 Pro | Unit: mm
Hi Brian
https://forum.punchcad.com/default.aspx?g=posts&t=11166#post43191 V16 New Features http://www.masterviacad.com/videos/page13/index.html V16 Copilot Improvements http://www.masterviacad.com/copilot/cad/index.html Tim
Edited by user Thursday, May 22, 2025 6:34:15 PM(UTC)
Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
Hi Tim, I cant log in to my profile Claus2 so created a new Claus3. However I can’t access the beta section of this forum, can you help. Are you planning to release a but fix for v15? I did report that protrude solid is not currently working. Thanks, Claus
Thanks: 7 times Was thanked: 79 time(s) in 45 post(s)
V16 New Features http://www.masterviacad.com/videos/page13/index.html All questions for MacOS
Thanks: 1 times Was thanked: 3 time(s) in 2 post(s)
Hi, I've just downloaded SharkCAD build 1732 to check the extrude from a face issue. I'm getting a repeated crash immediately after opening the app (Mac version). Nick
>>I've just downloaded SharkCAD build 1732 to check the extrude from a face issue. I'm getting a repeated crash immediately after opening the app Checking.... Tim
Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
I hope they start fixing all the bugs... Also support for silicon prossecor. There isn't any development anymore. And support..anybody there?
3 users thanked relaxibus for this useful post.
Thanks: 7 times Was thanked: 9 time(s) in 7 post(s)
Luis G.
Originally Posted by: Tim Olson
I just installed ViaCAD 16 2D. Shocked to discover it is STILL not written for Apple Silicon. Apple Silicon is over 5-1/2 years old. I'm running OS 26.5. It's almost a certainty that MacOS 27 will no longer include Rosetta.
The current beta version is
v17 Build 1912 .
V16 has a significant error with snaps. When the second point of a line is near the XYZ axis, it snaps to the axis and not to the snap point. It seems this glitch will only be fixed in
v17 .
Edited by user Saturday, June 6, 2026 9:04:06 AM(UTC)
