ctkjose
#1 Posted : Sunday, March 22, 2026 5:14:09 PM(UTC)
ctkjose
Shark Pro V16.0.41, Build 1841
macOS Tahoe 26.3.1
Macbook M3 Pro
1. Dynamic Rotate is unusable the refresh rate drops to about 1 frame (I'm not exaggerating) regardless of the amount of movement.
2. On the external monitor (main monitor) is completely unresponsive. On macbook's monitor it lags a littler less.
3. PS: The program windows become unusable if app is moved between desktops. No way to re arrange them.
ctkjose
#2 Posted : Sunday, March 22, 2026 5:21:19 PM(UTC)
ctkjose
Lowering the components resolution to medium made it fairly usable
Edited by user Sunday, March 22, 2026 7:36:17 PM(UTC)  | Reason: Not specified
Theo5715
#3 Posted : Monday, March 23, 2026 1:36:58 AM(UTC)
Theo5715
Netherlands
Was thanked: 47 time(s) in 28 post(s)
Your problem: Dynamic Rotate is unusable the refresh rate drops to about 1 frame (I'm not exaggerating) regardless of the amount of movement
If you like to rotate it's better to turn off the construction line (normally in construction layer), these lines are extreme long and ruins the dynamic rotation.
Good luck & regard, Theo
If things don't go the way you would find a way it could.
Win11-Intel Core i7-9700K CPU @ 3.60GHz RAM-32GB Shark14&Powerpack
thanks 1 user thanked Theo5715 for this useful post.
MPSchmied on 3/25/2026(UTC)
#4 Posted : Tuesday, March 24, 2026 3:38:31 AM(UTC)
macOS Tahoe 26.3.1
Macbook M3 Pro
This has been a pain for Long...
I gave up using 2 monitors with Shark
thanks 2 users thanked jlm for this useful post.
GARLIC on 3/24/2026(UTC), MPSchmied on 3/25/2026(UTC)
