TruggyDriver69
#1 Posted : Friday, April 4, 2025 12:29:55 PM(UTC)
TruggyDriver69
Like the time says. When I draw a shape on a face of the model it wont let me make a hole and it just extrudes through the opposite side. Site won't let me post pics so I can't share any.
#2 Posted : Saturday, April 5, 2025 12:53:29 PM(UTC)
Was thanked: 115 time(s) in 76 post(s)
Hello.
Without an image, many users may feel reluctant to get involved.
I'm no expert, but, maybe questions below can help you self-diagnose the problem you're experiencing. Maybe others know best which questions to ask you.
So...
First, the only relevant thing I can see to your situation is when I have a solid from joined surfaces, I try to create plates or floors "inside it", and the floor instead shows several pieces outside, not one piece inside. It sounds like you may need to shell the solid before creating geometry inside of it.
If that doesn't apply, maybe go through the following (for sanity checking or for familiarization):
About the thing you're trying to modifY...
— Is it a sphere/cube made as a surface, or is it a solid?
— If it's a solid, is it shelled or is it non-shelled?
The geometry you're using as the modifiER...
— is it a surface, a solid, or a set of curves? A tube?
Is the geometry natively constructed within ViaCAD, or imported from another app?
Are you trying any Boolean tools, or, say, using a surface to do anything. Is your install of the app letting you Boolean add/subtract/etc two spheres?
If it's a solid, try the Push-Pull tool or other available Modify tools in the menu or tool pallet.
As for surfaces, make a surface. Then, copy the surface and immediately paste back the surface. Drag it to the side where you can manipulate it. Use the menu or the keyboard shortcut for "Show points". A PASTED surface has control points you can access and use for manipulating the surface. I think of it as an alternative to using meshes.
(Speaking of which, are you trying to use a mix of mesh and non-mesh geometry? Using, say, a surface to modify/cut/extrude against a mesh? One reason I don't use meshes is years ago, I couldn't make surfaces extrude to meshes, and even if meshes are great, I view them as for mugs, faces, monsters, and similar. Sure, they can be used to make planes, cars, and much more, but I get stressed out doing anything with meshes, and rarely visit the mesh features.)
As a side experiment, can you create a sphere, then place two lines near it, make a surface from those two lines, and then use the split tools to split the solid sphere? Can you create a sphere and access the control points to reshape it.
Have you seen in the help manual the various tools that have similar purpose to what you want to do?
If the tools are "misbehaving", have you had any recent system or app crashes?
If none of those things work, maybe you want to reinstall the app if it's been many months last you installed it.
As far as being unable to post images, it can seem you can't but the "Attach files" check box confuses even me if I don't use it regularly. You need to attach a file, then *preview* it. Be sure to attach only supported files.
If you're too new an account or profile, there might be restrictions on attaching until you're posting new or response messages, or have read/used the forum some amount of time, but I can't remember if or how many you need to.
If you have an external, reputable repository or image site available to the public (and won't compel visitors to create accounts or ask them for passwords or privacy information), maybe put the image there and the link to in in your next forum message.
As for your installation of ViaCAD, is this on windows, or a Mac? Maybe a Mac user will be able to help.
But, again, without an image, many users may feel reluctant to get involved.
Try again to post, whether it's an image or the a ViaCAD file.
Theo5715
#3 Posted : Monday, April 7, 2025 3:05:38 AM(UTC)
Theo5715
Netherlands
Was thanked: 47 time(s) in 28 post(s)
Hi Truggy
As you say: When I draw a shape on a face of the model it wont let me make a hole and it just extrudes through the opposite side.
I presume that the shape must be the cutout (hole)
If the face is not flat it can give problems sometimes
Just extrude the shape and beware of the direction, you can use e.g. 1" or -1", up to you.
Then subtract the one from the other, done.
It's easy to link a file on this platform and easier for another to find the problem.
Edited by user Monday, April 7, 2025 3:10:31 AM(UTC)  | Reason: Not specified
If things don't go the way you would find a way it could.
Win11-Intel Core i7-9700K CPU @ 3.60GHz RAM-32GB Shark14&Powerpack
thanks 2 users thanked Theo5715 for this useful post.
ZeroLengthCurve on 4/7/2025(UTC), MPSchmied on 4/7/2025(UTC)
#4 Posted : Monday, April 7, 2025 12:00:32 PM(UTC)
There is a hole tool, but it may only be available in certain versions, otherwise, yes you have to draw a shape and extruder and subtract it.
If the surface is curved then yes it'll be an issue to draw on the face that's curved. You'll need to set up a plane and do it that way
